what should i get with this set up
Okay i have a honda civic all fixed up....i recently got a JL audio 13" inch w7....what else do i need to get as far as a amp..like what size amp....also do i have stock speakers do i need to spend money on new speakers...if so what kind?
Please clean that up with some punctuation. Did you just ask us if you have stock speakers, or did you you mean that you do have stock speakers? Also how much you looking to spend? What do you need?(speaker, sub amp, speaker amp, HU, alarm, electrical, and so on).
run the w7 with a 1000rms watt amp, Jl1000/1 would do it but it's crazy expensive, other amps will work for a lot less... I believe these amps will give you decent power at 3oms but i'm not positive... orion 1200d if u want to go high quality, viper1200, concept cc-d1200, etc..
stock speakers are fine, just use them for highs only
get rid of the stock speakers if you want better SQ. Most stock speakers **** for SQ... but if you want a loud system, just get that sub bumpin. How much are you looking to spend for the amp? You can get some real cheap ones that would still work but if you got a high budget, then there's some great options out there.
Do you plan on buying some other stuff too?
highschool2proz
highschool2proz
Durham, NC
DIPayton
