What should I do with electrical?
ChucklezZ
I have an SAZ-1500 right now which is fine on 2 ohms, but now I need to run 1 ohm and add a RF prime 300.4 . I'm pretty sure I have a 90 amp alt, I have big 3. Should I add a battery? 2. Get a bigger alt? or 3. Just get 1 good battery combined with the big 3? I don't know what the stock electrical can handle but I wanna be safe
Do the big 3 in 0 gauge wire and get a good AGM battery up front. I would do it in that order and if you still get voltage drop get a high output alternator. That's just personally what I would do since you need most of the space inside the cabin for your amps and enclosure
I have a XS power D3400 for about 3 years still holding voltage of 12.7. I think one of those would fit perfectly under the hood of your Ranger. What gauge wire is your big 3 done in?
what about the d925, I'm just wondering cause it says for 1000-2000w. and American bass 0 gauge
You'd only want the d925 if you were just adding it into your current system and not replacing the front battery. I'd go with the D3400, that battery should be plenty to run your sound system and start/run the truck.
You might get slight dimming running at 1 ohm but your voltage will be ok. Just make a separate 0 gauge run for your sundown amp and separate 8 gauge run to your other amp (don't use a distribution block)
ChucklezZ
ChucklezZ
Patton, PA
AndrewHD
