What should I do for this?
Alright here is the deal. I have an all rockford system. A p400.4 amp for my interior speakers and a p300.1 powering one sub. I also have the 360.2. None of this is hooked up to my headunit. I just have my mp3 player plugged into the 360. Everytime I shut the car off I get a thump just from the sub. The amps remote wires are hooked to an accessory wire in the driver side foot panel. The 360 is also hooked to the same wire and is grounded at the same spot as the p300 amp.
Now this is what I've tried.
I first unhooked the 360's ground thinking it was a ground problem. The sub still thumped
then I unhooked the 360 from the accessory wire and the thump stopped.
I then hooked the 360 up to the ignition wire and grounded it at the same spot as the p300. Instead of the sub thumping when i shut the car off the speakers hooked to the p400 thump.
I got pissed so I just hooked it back up the original way
I'm confused I don't know what to do. Do you guys have any ideas.
your problem is that accessory wire. run you a switch or a relay instead of running it of that wire. run a hot from 12v or from the acces wire to switch then to amps. the problem with just going from 12v constant to switch is you have to remember to turn off the switch. but if you use a relay you could go from 12v constant to relay then use the acc wire to switch the relay that should do it oo.
sleeperjake
sleeperjake
charlotte, nc
Horsemanwill
