What is this Box tuned to?
Qbenjamin
I posted vids of my sub inside my box (Box has separate chambers), which I thought didn't sound too bad. Well I was wrong. It sounded like ***. I thought that my box was 2.2 CUF tuned to 32 HZ, but now I don't really think so. I tried adjusting the gains on my amp to get that muffled noise out, but much to my avail, nothing worked. Here are the measurements of my box (Everything was measured from the insde of it):
Wood = 1" (Souldn't need this, since I measured inside, but I posted anywayz)
Depth = 14.5"
Width = 15.5"
Height = 14"
Back Port Wall = 9"
Side Port Wall = 12"
Any and all help would be appreciated. I don't want to go sealed, but If I can't figure out what this box is tuned to, then I will
I understand that you build a box based upon the sub that you are going to put in it. I already had this box, and this is what it was supposedly tuned to.
Well, in that case, what would the box be tuned to if I put a FI Q 12" in it? I have the D1.
Q12
DUAL 1 | DUAL 2
Fs: 28.4 Hz | 27.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 05.39 | 5.63
Qes: .49 | .48
Qts: .45 | .44
Mms: 211g | 231g
Cms: 0.15mm/N | 0.15mm/N
Sd: 481cm^2 | 481cm^2
Vas: 48.3 l | 48.3 l
Spl: 85.4dB 1W/1m | 84.8dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: .8-1.5 cuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
You cant just stick a sub into a box "tuned for X" and expect it to work like it should.
//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Don't ask why I thought otherwise........//content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
Would you like me to run the specs for you in Bass Box 6 Pro?
Please, before I beat the hell outta my equipment. It sad when someone tells you that their CVX sounds better than your Q........//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
Im not a pro with this program (actually I now realize I **** unless the driver is already loaded in the program, which Fi is not), especially when it comes to manually entering the data and converting that to a box design, so my intial result was so whacked out Im sure it wasnt right.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I'lll keep trying, or maybe someone else with Bass Box can chime in with an accurate result.
Qbenjamin
Qbenjamin
Braavos
Qbenjamin
