What is the biggest baddest 5-6 channel on the market??
Well hopefully its more than say 50x 6...cause thats not enough headroom for my needs. And If I were to rid of my amps it would only be to run 2 amps total...one 5ch/6ch perside but I need at least 500rms @2ohms for the subs and 3sets of inputs
Only amps that fit that bill is the A7 and the Arc Foose 6ch that is coming out. I believe the Foose will be ~80 x4, 125 x 2 (chs 5/6 making 400 rms bridged at 4ohm, ~500rms at 2ohm) Which ideally watt per watt can replace all my amps just about.
But what nice about the Zap is no need for processor.
Yessir; I'm liking the pair of DC350.2's I'm using in the truck. Only issue I have it a a very slight turn off pop (even RCA's not connected to Symbilink adapter), but Robert from Zapco said to reflash the amp and it should go away...to be honest, it's really not worth doing as the wife drives the vehicle 90% of the time, and the vehicle has to be off to hear it.
4x 130 Watt at 2 Ohm analog + 1x 530 Watt at 2 Ohm digital, 4x 100 Watt at 4 Ohm analog + 1x 350 Watt at 4 Ohm digital or 2x 250 Watt (bridged) at 4 Ohm analog, State of the Art MosFetAmp, Burr Brown OP-Amps and Foil capacitors in Signal path, Top Control, Bass-Level-Control, Highpass (20-4000 Hz, disengageable), Lowpass (20–4000 Hz, disengageable) for the analog channels, Lowpass (40-200 Hz), Subsonic (10-55 Hz), Phase (0-180°), 1-Band-Parametric EQ for the BassAmp.
Xetec P5 Evo
http://www.xetec.de/main/index.php?cms_menu_id=247&language=en
My "mint condition cosmetically, perfect working A7" should arrive thursday.. I keep saying that line because that is what I am promised and saying a prayer I will not get a beat up used turd of an amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif :peace: //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif :peace: //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif :peace: //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif :peace: //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
haha, please no scam. we don't need anymore as bad as it is already.
on another note, once you don't get happy with the amp, i'll be glad to take it off your hands //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
desertheat
desertheat
Tempe, Az
alphakenny1
