- Price
- $349
- Condition (1 worst - 10 best)
- 10
- Location
- Boise, ID
SIQ 75.4 (Class A/B) – StereoIntegrity.com
Hi-Fi class A/B and class D amplifiers are back with our SIQ amplifiers. Full bandwidth, zero filters, discrete gain knob per channel, zero crossovers, zero EQ. Purity at its finest. Being avid audiophiles for over 25 years we have always appreciated the finer performing amplifiers in mobile...
(Price is shipoped lower 48)
These are the real deal SQ amplifiers. You have to pay quite a bit more to equal the sound quality, the clarity, and the sparkle these amps provide. It's a pure signal path to the amplifier sections, no electronic crossovers, and nothing between the signal you give it and the amp section except for a gain control.
This amp is new, opened to bench test only, and never installed! I've repackaged it even better than the way it came.
From SI
Hi-Fi class A/B and class D amplifiers are back with our SIQ amplifiers. Full bandwidth, zero filters, discrete gain knob per channel, zero crossovers, zero EQ. Purity at its finest. Being avid audiophiles for over 25 years we have always appreciated the finer performing amplifiers in mobile audio and with our growing presence in the mobile audio industry, we have been able to team up with talented amplifier engineers and finally produce our own hi-fi amplifiers. Audiophile components were used throughout construction and engineering to bring our amplifiers to fruition. And because we are a direct company (no dealers) the cost savings are passed directly to you, our customers.
All of our SIQ class A/B amplifiers utilize audiophile-grade T0-3 output transistors, clean board layouts, thick extruded aluminum chassis, copper anodized shielded transformer covers, and a large plexiglass viewing window. Coming inward we use UPC4570 op-amps followed by IRFPO64N power supply transistors, sand cast resistors, surface mount parts to save board space, and Tiffany-style RCA connections. All of the above FR and power graphs are from Audio Precision measurements.
Amplifiers Specifications
Quick Info
| Frequency Response Minimum | 5 Hz |
| Frequency Response Maximum | 150,000 Hz |
| Signal-to-Noise Ratio (SNR) | 90 dB |
| Total Harmonic Distortion (THD) | 0.03 % |
| Dimensions (W x H x D) | 14 x 8 x 2 Inches |
| Rated RMS power output into all 4 channels at 4 ohm | 75 Watts |
| Rated RMS power output into all 4 channels at 2 ohm | 120 Watts |
| Bridged RMS power into 2 channels at 4 ohm | 120 Watts |
Connections
| RCA Input Maximum | 16 Volts |
Power
| Idle Current Draw | 1.2 amps |
| Maximum Current Draw | 66 amps |
Price is shipped to the lower 48—payment by PayPal F&F unless you want to pay the fees for PayPal G&S.
- Was Photo Included
- Yes
- Was Note Included
- Yes
