what guage power wire?
  • 5
horford
27
kentucky
What's the recommended guage of wire to connect a RF 250 D class amp to the battery? The instructions don't specify. I've got some 16 guage, i think left over from my old kenwood woox powered sub i had many years ago.
yeah, 8. Or go for 4, in case you want to upgrade. I did that, and was really happy I did. Made installing a second amp a breeze, since I didnt have to run a new power wire all the way from the battery to the back of my wagon.
As a rule of thumb, 4ga can handle up to 1000wrms.
I don't know if your Rockford amp is like mine, but it was a PITA to get 4ga into the terminal cups of my amp. I'd say go for 8 unless you have adapters to go into the amp itself. You won't benefit at all going with 4 unless, like sj said, you can just upgrade the amp without running new wire.
rated power: 125x1 @ 4 ohms / 250x1 @ 2 ohms
battery fuse rating: 25A
fuse on the amp: 30A
so 8 guage is the way to go?
and stupid question, but the ground wire size isn't as crucial, right?
rated power: 125x1 @ 4 ohms / 250x1 @ 2 ohmsbattery fuse rating: 25A
ground should be the same size as the power. It's a flow...
power --> amp --> ground
Ground should be as big or larger than power. You NEVER want a smaller gauge ground wire than power. It's a recipe for disaster.
eh ****; i guess i gotta blow some more money...but i'm glad i asked; i want to do it right...thanks guys
---------- Post added at 08:53 PM ---------- Previous post was at 08:53 PM ----------
what about the switched power wire that i plan on running to the stereo wiring harness? that's not part of the flow?
No it's not. Knu has a set of RCAs that includes a remote turn-on lead. I've had good luck with mine and, at 7 bucks, super cheap.
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
192
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
554
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
410
horford
horford
kentucky
horford
    May 18, 2024
    May 16, 2024
