what guage power wire?
yeah, 8. Or go for 4, in case you want to upgrade. I did that, and was really happy I did. Made installing a second amp a breeze, since I didnt have to run a new power wire all the way from the battery to the back of my wagon.
As a rule of thumb, 4ga can handle up to 1000wrms.
I don't know if your Rockford amp is like mine, but it was a PITA to get 4ga into the terminal cups of my amp. I'd say go for 8 unless you have adapters to go into the amp itself. You won't benefit at all going with 4 unless, like sj said, you can just upgrade the amp without running new wire.
rated power: 125x1 @ 4 ohms / 250x1 @ 2 ohms
battery fuse rating: 25A
fuse on the amp: 30A
so 8 guage is the way to go?
and stupid question, but the ground wire size isn't as crucial, right?
rated power: 125x1 @ 4 ohms / 250x1 @ 2 ohmsbattery fuse rating: 25A
ground should be the same size as the power. It's a flow...
power --> amp --> ground
eh ****; i guess i gotta blow some more money...but i'm glad i asked; i want to do it right...thanks guys
---------- Post added at 08:53 PM ---------- Previous post was at 08:53 PM ----------
what about the switched power wire that i plan on running to the stereo wiring harness? that's not part of the flow?
No it's not. Knu has a set of RCAs that includes a remote turn-on lead. I've had good luck with mine and, at 7 bucks, super cheap.
horford
horford
kentucky
horford
