What gauge wire?
Two 12" Type-R's powered by a HiFonics 1206D. The box is 5 cubes at 32hz. By sealed up I mean caulking the corners and edges inside.
hmmm.... your specs and power seem fine.. basically exactly what i currently have,, although im adding more power in a couple of weeks. Is your power supply sorted? what ga power and ground wires are you using? Which direction are your drivers and port firing? Maybe playing with that and moving things around could give you better results.
thepope3290
thepope3290
Thomson, IL
blackbonnie
Mike Mccabe
