Simple Question
skisloski
NY
I went out to do my big 3 upgrade today and found that all of the connections i needed to make were inaccessible (sp). Im running ~1000rms
Questions:
Should i add a second battery even thought i cant do the big 3
With the second battery, do i connect the ground from my battery in my hood to the second batter, or make a new seperate ground for hte second battery
Would it be beneficial to do a big 3, but for instance on the battery to ground (cant get to where it grounds now) should i run the wire from my battery to a new ground that i make or does it have to be on the same spot as the current ground
Questions:
What kind of car do you have? What is making things so inaccesible. Is there one element in particular?
If you get a second battery, you can either hook up the batteries + to+ and - to -, or you can connect the + to + and round the new battery somewhere else on the car. If you are already going to be running one line for + i would just go ahead and connect both + to + and - to -. Just my preference though.
And no, the new ground does not have to be in the same spot as the current ground.
skisloski
skisloski
NY
funkyab
Mike Mccabe
