what frequency pulls the most voltage?
Higher frequency means the signal just switches back and forth more often, which usually requires less total power use throughout the entirety of the sinusoidal curve. Enclosure and environment have say on this too though. Burps are different because a system uses the least power at resonance however.
Increase the amplitude (lower frequency... sorta, I can explain further if you'd like) you will use more total power.
Falcons
that **** i dont like
Falcons
Albion, New York, United States
surreal
