What frequencies should an average SQ sub install focus on?
  • 5
aRandomUserName
If your not going for SPL, or high end SQ, and you are just adding some lows to a stock system, what frequency range would you shoot for with your sub install? 30 - 80 or so? May mid twenties to... how high? I want to get some test tones on a disc and see where my installation is making the most sound. It is a little peaky and def has a sweet spot somewhere around 45-50hz. When you play back test tones, where do you want to hear the peak at? i know the goal is flat with a high end SQ install, but I am not shooting for that..
I am assuming you are referring to the common 4th order bass reflex enclosure. With today's use of drop tunings on instruments and electronic generated sounds, music actually reaches lower as a majority in recordings than from decades past. Tuning @ 40 hz was accepted for most recorded music 20yrs ago, and now it seems the norm is anywhere from 1/2 to near 3/4 octave lower to extend low frequency extension. If your purpose is for SPL, then perhaps the 40-45hz tune may be your calling to achieve higher gains by using the vehicles resonance to your advantage.
🤣 good catch got me on that one. Around 120 hz is when they kick in. all that info is at the beginning of the thread. Sony XS-162ES’ are what I’m...
29
The CT's are nice, That Sundown is a a frik'n beast!
883
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
735
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
848
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
aRandomUserName
aRandomUserName
Atlanta, GA
quackhead
