What else do i need?
jamesmington
I'm collecting all the parts and pieces to build my system, but I'm not sure what else I would need? Do I need a capacitor? new battery? and i need info on all the wires i need...what gauge? what type of rcas? distribution blocks? any help would be great!!
so heres what i got:
Eclipse CD7000 with harness wires
CDT EF-51 components which will be hooked up to...
AudioArt Na- 2120x (240 watt amp)
MB Quart QM 160 which will be hooked up to...
4-channel Alpine MRP F-257
Memphis 16-CX35A crossover
Memphis CA300 (150 watt x 2) that I will hook up to a 12" orion hcca sub, that ive yet to purchase...
here are pictures...
so hows everything look and what do i need?
thanks!
Why are you using the crossover? I don't know a lot about the Eclipse CD7000, but it has 3 preouts. It must have some crossovers in it to low pass the sub out and high pass the other 2. You don't need the external crossover then.
Here's what I'd get:
-2 distro blocks with 1/0 in and 4 out. One needs to be fused, the other doesn't matter
-35 feet of 1/0 gauge power wire, enough for power, ground, and the big 3
-20 feet of 4 or 8 gauge, it depends on what kind of power inputs the amps have...so check on that and get back to us
-100 feet of 14 gauge speaker wire. Brand isn't a big deal, I get 50 foot spools of the generic car audio brand at Walmart for like $13.
-3 pairs of 20 foot RCAs. KnuKonceptz is a great brand, I am running them and am very happy with them. Not too expensive either.
-20 feet of 14 gauge wire used for the remote line.
-A crapload of crimp terminals (disconnects, ring terminals, butt connectors), all sizes of heat shrink, a lighter, electrical tape, and liquid electrical tape.
the rear mb quartz speakers and the crossover are free which is why i have em, figured theres nothing wrong with the option of rear fill, i can fade front and back whenever.
As for my amps...
The only info i could find on the alpine was:
"Alpine MRV-F257 1998-1999 280 watts Rms "
Audioart is 240 watt
Memphis is 120x2
im guessin itd be best to just get both the distro blocks and rcas from knukonceptz?
thanks for the help!
anyone else got suggestions?
how do you figure rearfill is gay? i would like a detailed explanation on this.
Yeah, I wasn't aware that rear fill had a ****** preference either. I guess if you think about the words "rear fill" enough they could possibly allude to something, but only if your mind is in the gutter.
jamesmington
jamesmington
houston
jamesmington
