Car Trekker
Speakers, Speakers Speakers
"You can't polish a turd"
While most electronics rate their distortion at way below 1%, you'll notice that almost no speakers have distortion specs...why?
Because the are typically 10%, and even more with some cheap ones.
A good set of components may get below 5% THD with a good install behind them.
No amount of EQ can lower the distortion on a cheap speaker.
Another phenomena....Change up your components, and your subs will sound cleaner. Our ears take their quality cues from the mids and highs, so even the same bass will appear to improve with cleaner top end.
The system is only as good as it's weakest link, and while the source is important, it takes a good set of speakers to be able to hear the flaws in the source, or amps.
Dollar for dollar the best upgrade is speakers.
I've had installs make it to the finals without an eq, using cheap amps and subs, great speakers, and awesome install. Of course they didn't do well against the big $$$ 30 band eq'd systems, but they spent less than $5k!
After that it's $1000 a point!
