what build?
Your electrical ALONE will cost you $1k I'm telling you by experience. I used up a 50ft roll of 1/0 which was $180, 4 fuse blocks and fuses like $55, 2 batteries $600, HO alt $500. That's electrical ALONE. Then your amp subs and box? Close to $800 probably. Then you still need your mids and highs $200 for 2 sets of components. The. Installation unless your doing it yourself.
Here man
This is pretty much what you can do for a single cab with bench seat.
(2) sundown sd 2-10 $330
Used soundqubed q1200-around $200 or new your choice
1/0 amp kit $100
1/0 big 3 kit $50
Custom box around $200
Upgraded front batt $300
Upgraded 200A alt $300
That's $1480 leaves you with $20 for a sticker or something.
And save up some more money for your mids and highs which will get close to $300 with amp kit district block and 2 component sets as you described you wanted
**** it's expensive. For bass extended cab is crazy better. Are CVRs or MTX subs serious ****? Cause why are they so cheap? Budget custom builds are $2,000. The first system plans came in just over 2k with everything.
certain lines of kicker and mtx are just that. cheap. when you get into the nicer products the subs get better. it would be better/easier if you had an extended cab truck as you could build in the extra area in the back. if you want a real system then it will cost at least $2k unless you get some screaming deals on used products like a 2kw amp for like $200 and some subs for the same price. wire is going to be a killer with that much power. as well as extra battery. can get a kinetik hc2400 for $240 on sonicelectronix.com
sanguine79
Carthage, NC
BoomTaco64
