Can tweeter turn on pops be harmful?
Just installed an alpine pdx f4 to use in an active 2 way setup and there's a slight pop from the tweeter when you turn the car on. I dont really mind it but can it harm the tweeter? I have a cap inline
If you have a cap inline its not active. Active is crossover before power. It shouldnt harm them but it should be fixed
Its only used for protection, cuts any frequencies lower than 1325 hertz. I have the HPF for the tweets on the active crossover set to 3500 hertz so its fully active
What is triggering the amplifier to turn on? Is it turning on before the head unit? The capacitor is providing some protection. Don't remove it.
The remote turn on is triggering it (no relay) and its hard to tell, they turn on pretty much at the same time.
You can use this
PAC TR7
Product Description
Combines multiple features into one SKU covering more than 16 different applications including low voltage trigger, Alpine video bypass, latching output, double pulse output, pulse extender, linear actuator controller, channel splitter and more!
Product Features
Low voltage trigger
Alpine video bypass
Latching outputs
Double pulse output
Pulse extender
Linear actuator controller
Door lock pulse generator
Channel splitter
3 in 1 timer outputs
Pulses to timed output
Turn on pop delay
Delayed amp turn off
alexdbest2000
alexdbest2000
NY/Canada
trumpet
