What amp should I get
A bit more info would be needed to give you an actual recommendation. The model of the drivers you're using would help. Also what kind of enclosure do you plan on using...it will determine what kind of features your amp may need...like if you're going to go with a ported enclosure then you may want an amp with a subsonic filter etc. Do you have certain budgetary or electrical restrictions? Are your goals more SQ or are you lookin to shake the block?
Yeah man, you need to advised you want to pound the pavement or more an SQ dude!  Also please provide us the model number of your subwoofers so we know its single or dual voice coils.  Also your ride so we know its not space restricted in size. Cheers mate!
They are 600 watt 10 inch massive TKO104 subs, in a Qbox! My truck is a 2006 dodge 4door under the back seat!
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
Basshead12
Basshead12
Boomin_tahoe
    Apr 28, 2024
    Apr 28, 2024
