What amp should i get?
jbl sound like a good choice //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif possibly a bigger jbl, like a 600.1 as then when u upgrade it will be more useful and that way u can tuirn the gain down and the amp wont eat as much battery power than a pushed 300.1
I would say to get the JBL 600.1, but you might be tight on budget. IF you are, and im not saying you are, then i would look into the Profile 800SX. It does 200w rms @ 4ohms. I think that they are overrated so you will get roughly around the rms of your subs.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
8
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
crucifiedsoull
crucifiedsoull
Temple, Tx
MikeofTulsa
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
