What am should i use???
Jmanisaac88
ohio
I dont really know a whole lot bout car audio nd i needed some help. I was looking to buy 2 comp 15" Kicker 07C154 and i was wondering what kind of amp i would need to push them. They have:
  • 1000 watts per pair / 500 watts each PEAK
    500 watts per pair / 250 watts each RMS
    4Ohms
    sensitivity of 90.2 dB
    Single voice coil
I dont want to pay a lot for the amp i just need some specs and or recommendation on what i should get or look for thanks
1. you're already going the wrong way with going with kickers. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
2. since its SVC, you can run it at 4 ohms. or 2. so look up amps with 250 rms @ 2 ohms or 4 ohms.
yeah, 2 channel with 250 rms per channel. since you said your subs are 250 rms? if you miswrote it and it was supposed to say 500 rms, then find an amp that has 500 rms per channel. or if it's a mono block, u can look for a 1000 rms and just hook both subs up to that.
Jmanisaac88
Jmanisaac88
ohio
SRim23
