I have a Cascade Designs Omega 15" D1 in a 3.5 cu ft compression box with aeros tuned to 32 hz.
I am wondering if it would be ok for me to wire the sub to 0.5ohm load since after the impediance rise, the amp will end up seeing 2 ohm?
ZX2500.1 is rated 2500 at 2 ohm
I m trying to see if I can get the more out of this amp by doing this because from what I have figured, if I wire the sub to 2 ohm load then after the rise the amp will be seeing some more than 2 ohm. Am I making any sense?
Any help would be appreciated, thanks.
