What’s the tuning??
That's 1.5" baffle only like the drawing?... tell me the driver and I'll try to account for displacement... maybe model it... what do you plan?
it was originally designed for a CT Exo 15” on a CT4K. It was going to go into my Avalanche.
What's displacement on that?... i can look it up... if your changing subs lemme know... I'll use the new one to model it if you'd like
The newest one will be fine to model off of. As of right now, that’s the plan. Last I checked it was .25 for displacement on the 15”.
I couldn't find parameters online... do you have them?.. Then I can give you a HARD number.
Or at least the best I can come up with... lol
Here is what I have for the 15”
T/S Parameters
Dual 1 Ohm
Fs 30.796Hz
Qts 0.307
Qes 0.329
Qms 4.573
Vas 36.857
Sorry had to leave for a second... is that area in the drawing that says 4.5" at the back wall closed off? or is it a brace?.. I'd like to try to give ya an accurate result
It does appear to be completely sealed off. I’m not sure why though.
It's either this...
Or this...
Volume depending on the piece I asked about... anyways it ought to be close... looks like 32-33hz to me
It's either this...
Or this...
Is that for both ports? From my understanding when it was drawn up it was a form of a 6th with 2 different tunings.
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
oxsign
No Affiliation
oxsign
Orlando, FL
oxsign
pfft
    May 1, 2024
pfft
    May 1, 2024
