mastarecoil
I am trying to hook up an automotive relay for turning on my amps. I have tripled checked that my wires are okay.
30 to battery
87 to amps
86 to trigger supply
85 to ground
My trigger supply is a power antenna turn on. This car has no power antenna, so the relay is the only draw to this source. I have read about others sucesfully using this as the remote input for their amps (with and without a relay) so I believe it should provide enough current, those automotive relays dont draw much anyways.
When the power antenna wire is not connected to the relay, it reads a nice 12volts. When it is connected, however, the relay does not trigger and I only measure 1volt.
Does anyone have any idea what could be going on?
Thanks!
30 to battery
87 to amps
85 to ground
Thanks!
