Weird relay problem...
mastarecoil
Indiana
I am trying to hook up an automotive relay for turning on my amps. I have tripled checked that my wires are okay.
30 to battery
87 to amps
86 to trigger supply
85 to ground
My trigger supply is a power antenna turn on. This car has no power antenna, so the relay is the only draw to this source. I have read about others sucesfully using this as the remote input for their amps (with and without a relay) so I believe it should provide enough current, those automotive relays dont draw much anyways.
When the power antenna wire is not connected to the relay, it reads a nice 12volts. When it is connected, however, the relay does not trigger and I only measure 1volt.
Does anyone have any idea what could be going on?
Thanks!
Hmm sounds like you have an interesting problem. The relay is def. wired correctly. You check for a short on the remote line? You sure you have 12 on the amps power wire?
Yes, I am sure there are no shorts and that their is 12 volts on the power wire.
Also, I connected a constant 12v source to 86 (where my power antenna should be) and it worked just fine.
Hmm seems like your screwed then. There must be something wrong with that power ant. output. I cant see a relay requiring that much more amperage to trigger than the power ant wire can output that it would drop down to 1v. Why now just jump over to the accessory wire?
Its a 2003 Taurus.
There is no accessory wire or any other wire to connect to. THe power antenna wire is the only power source which turns on and off with the radio, the rest avalible are constant.
is there still 12v on the power antenna lead when in cd mode?
plus relays usually only require 100-200 approx, milli volts to activate and i can assure you that that is present in that lead, try running a wire from the fuse panel into an accesory then run that to the back and try that
Ok i'm not sure bout the taurus but I know a lot of newer fords only use a 5 volt turn on. So maybe tis not really 12 volts to begin with on that line? But forget my statement earlier about using the acc wire for the radio as I am sure you want to amps to turn on and off with the radio. Your best bet in this case would be to use a low voltage trigger. They only require about .5 volts to turn on and will output
12v. So the 1v you are getting should activate this piece. But if it doesnt a low voltage trigger can also be hooked up to a speaker line and will activate from that signal.
I know peripheral makes one but I dont know who might have it for sale. I know radio shack used to carry one but I dont think they do any longer. I will try a quick search for you.
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
mastarecoil
mastarecoil
Indiana
project f-150
kanihoncho
    Apr 28, 2024
kanihoncho
    Apr 28, 2024
