Weird rca question.
  • 4
Jeremy11
Ok this is going to have some of you saying wtf is this guy thinking? Anyway if you were to take three sets of rca’s that had split frequencies, one set high, one set mid range,and one set subwoofer and put them into an rca block like the one I have attempted to attach, would the signal go to full range? The dumb thing I am trying to accomplish is to run my pioneer head unit in network mode to my amps and get a full range signal split to an equalizer only for the light display, it won’t actually function in the system. I checked by sending different frequencies and only the bars representing those frequencies lit up on the eq face do I need a full range signal to get my light show.
Out of the box, but I like where this is going. So you do not have a full range signal to feed into the input? Another question, did you feed these signals into the inputs and powered the eq, OR, did you feed them into the outputs with the eq off?
I have serious doubts about this working. The reason y-cables (effectively what you have there, but a 3 way) works is because you have one source and 2 or 3 parallel loads. Going the other direction you have 3 sources fighting each other (shorted). There's no way the product of that is something sonically useful. My guess is there's a better chance it would damage the hu outputs.
Does the eq have high level inputs? Just use a speaker lead. Or even a cheap LOC. Makes more sense to me.
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
985
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
Jeremy11
Jeremy11
Loganville,GA
n2audio
Bobbytwonames
    Apr 20, 2024
Bobbytwonames
    Apr 20, 2024
