weird idea
taintedplay
ok, currently i have two tens in my car. they arent really doing what i want (came from 4 15's)
bear in mind this is probabbly retarded
I still have the 15s laying around and i want to build them in. but, i carry normally 2 other people so i cant wall it all off. So im trying to think of alternatives. My trunk i could prob only get 10sqft at the BEST. doubt even that. so i had an idea. i have one of those ski port things in the middle seat. would i be able to extend the box out through that?
that way the box would take out the middle back seats, but leave in the side ones. here are some quick sketches i did. the thing part in the middle is where the ski port would be. the biggest side is the trunk box and the smaller side is the box over the seat and to the floorboard
I could either port it inside the cabin t the end of the box, or vertically along the rear deck.
So thinking through the rear deck, would like subs back port up with the inside cabin portion just adding to cuft work?
You can make use of the airspace to try to make it into a BP but you should get some of the BP gurus to help you out with it if that's what you want to do. But the way I see it at the moment, is that portion will actually be rendered as unusable/dead airspace. Essentially, as if it wasn't there.
ok did some measurements. i could get max 3sqft there by using max dimensions.
would i be able to do like 1 15 ported in the cabin box, and in a seperate box have the 3 15's in the trunk ported. i could even do them the same way. ie in both box port up, and sub back (or forward in the cabin box)
does that make sense?
taintedplay
taintedplay
dallas
taintedplay
