Ronny
I have read that when using multiple ports one must extend the length of both of them to reach proper tuning. I am hoping to keep right around 40hz tuning frequency. Can someone explain, or even calculate for me if it is easy enough, the length that both ports need to be? The box specs are 4 cubes after sub and port displacement in a trapezoidal enclosure. Also, with the aero ports from parts-express, you calculate the total port length needed, then subtract 3" from the center tube, cut it, and add the flares correct? Then the total length of the tube and flares when assembled will be one inch longer than the total length needed to achieve the tuning frequency?
Thank you much,
Ron
Thank you much,
Ron
