WANTED 3000 rms @ 4 ohm
LOL you've never seen the higher end stuff in action HUH?
these are not to shabby
http://cgi.ebay.com/NEW-MA-AUDIO-EHO...d=p3286.c0.m14
ur right the model u looked up dont look to shabby but im pretty shure my model looks better
i dont have a camra so i had to get it off line
Ill offer a little info...
If this is your speaker, http://www.dealercostcaraudio.com/hk15x2.aspx
then you dont need 3000w, and you dont need it at 4ohm either.
RMS on that sub is 2000, so thats what I would be shooting for, or even something under that number. According to the specs, the sub is a DVC 2ohm, so you could wire the VCs in parallel and get a 1ohm load. Be much easier, (and cheaper) to power it like that.
Just some suggestions..
yea when i rote that out i messed up
but yea i have it wired at 1ohm but the amp i have is 4000 at 1ohm so im looking for suttin a lil smaller
Just keep the boss amp and build a new box for your sub, thats probably why its not loud enough for you. What size are your power and ground wire on the amp?
they are either 4 or smaller guage but im almost positive they are 4 yea its most likely the bot bc right now the box is just big enough for the sub. it was a freebe box bc i didnt have a box at the time
yea but i had the sub power at 600 and my boss amp does bump louder. on the boss amp if its wired at 4 ohm the rms is 1550 not 500 nd i got mine wire at 1ohm nd its geting around 3000 or more im not braging because that really is not that many wattage but befor you try saying suttin make shure ur right b4 you do
Look buddy I hate to tell you this but that Boss is in NO WAY ON EARTH putting out 3000 watts at any ohm load. or Is going to put out over 1000watts. You are looking at a very low end amp. Just look at it this way. Do you really think you can pull that much watts with 4 gauge inputs NO. ask any amp guy on here. There is somthin else wrong with your system, Mabye even you, no offense. But start over from scrath. Look up the box size build the correct box. Make sure you have a good ground for the amp. Or just take it to some one who knows how to install. But once again. THAT BOSS AMP IS IN NO WAY ON EARTH GOING TO EVER PUT OUT 3000 WATTS.
hey well look hear buddy how would i be able to tell how many watts my amp is putting out. because i really wanna kno how many watt im pushing now that you said that.
bsheltry55
bsheltry55
Pittsfield, MA
bsheltry55
