Want to upgrade from SA-8v2's. Want more SQ. Need suggestions
You could go nuts and set yourself up for IB. You'll end up saving weight in the trunk of your Pontiac and afford yourself nice, flat low-end extension on low power.
[quote name='neo_styles']Like I said, I'm pretty impressed with the Level 2 10" on HALF of rated power. It will take significantly more than rated as well. Impact and punch has a lot to do with how your system is tuned as well. 600W would be perfect for a Level 2 and it'll run you under 200 shipped from @mylows10 ;
You do get a cone area advantage from a multi-sub setup, but how much of that G6's trunk do you really want to have an enclosure occupy? For ported, you'll want 1 cube or more for each sub.[/QUOTE]
I can fill the entire trunk for all I care. I don't like putting stuff in my trunk when I have subs in it. Don't wanna risk something getting in front of them and causing damage.
And is that under $200 shipped to Canada?
---------- Post added at 07:50 PM ---------- Previous post was at 07:49 PM ----------
[quote name='neo_styles']You could go nuts and set yourself up for IB. You'll end up saving weight in the trunk of your Pontiac and afford yourself nice, flat low-end extension on low power.[/QUOTE]
What exactly is infinite baffle? Isn't that basically free air?
Talk to mylows and see what he can do for you. He might manage to get your stuff sent USPS instead of FedEx/UPS to avoid the nasty customs/freight charges and delays
IB is where you completely isolate the front and rear waves of the sub from each other. Your entire trunk basically ends up becoming your enclosure, but to pull this off, you need to make sure the area around your baffle is COMPLETELY sealed or it won't work properly. It's the same reason you get better midbass response out of door speakers installed in properly deadened doors.
Except to take up the whole trunk like that the box/boxes would have to be built IN the trunk wouldn't they? I can't do that because I can't build. I've never built before and my current living conditions (apartment) prevent me from trying :p
Look for KHA's 2001 Accord build log. His pictures go through the steps he went through to make his system IB. Of course, in typical KHA fashion, he goes WAY above and beyond what most installers would do. Here's an example of his IB setup:
---------- Post added at 07:55 PM ---------- Previous post was at 07:55 PM ----------
Refer to my above post with pictures. As for getting the cutouts made, just do a mockup with cardboard and take it somewhere that will cut for you or ask a buddy/local shop to cut the shapes and just pay them a 20
Oh OK I see what you mean now. I don't think that's going to be an option for me. Looks expensive as hell to make it look good :p and also I have no blow through port in my car like he does to make that work the way his did
If that's the case and you want to use 600W each from the Audison, your best bets are the HO, Level 2, LI, or GCON. IIRC, all are 600WRMS subs, but the Dayton is the only one I'm unsure of regarding how much more than rated it will reasonably take long-term
Well considering the daytons are rated at 700W then I shouldn't have any worries about over-powering them with my current amp
---------- Post added at 08:03 PM ---------- Previous post was at 08:02 PM ----------
And which of those would you say could handle super fast transients the best?
---------- Post added at 08:03 PM ---------- Previous post was at 08:03 PM ----------
While getting loud and hitting hard
With the exception of the Daytons, I really think it's all apples to apples. The one I can speak most personally about is the DC since I'm currently running it and, for the price, I'm astonished. Came from a ID10 to this and the difference is night and day. Best way I can describe how the Level 2 reproduces bass is...effortless and deep. Like I said before, it's more a part of the rest of the system now rather than just being a showboater sub that steals from the overall enjoyment of my system. I came from SQ roots and am moving towards just looking at quality Daily Driver setups and wouldn't hesitate to recommend that DC to anyone looking for something around that power handling all the way up to 1K.
That being said, I REALLY want to get my hands on some IA Death Rows for a Tahoe build I'm planning out, so it ultimately is up to you.
Now when you say it's "not a showboater" that makes it sound like it doesn't really get THAT loud. I want a sub that can be leveled to blend with the rest of the system but at the same time can crank that fuc*** up and shake some sh** loose haha.
I usually play my SA-8s pretty conservatively but they can be cranked and shake the hell out of my car pretty well. They just don't have that fast transient response that I miss from my Hertz ES300
---------- Post added at 08:19 PM ---------- Previous post was at 08:18 PM ----------
Case in point
Case in point
Everyone's perception of loud is different.
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
554
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
682
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
818
gamehawk55
gamehawk55
Victoria BC, Canada
gamehawk55
    May 31, 2024
    May 24, 2024
