want to build a pair of MTM speakers
LilBassGuy
Hey guys
Haven't posted in awhile. Ever since i built those zaphaudio hivi bs3 projects, I have just been sitting back listening to music on my computer. Now, it is time to start planning a simple yet great sounding mini home theater.
It is going in my apartment, and will be used for both music and movies. I am not going to do a surround sound setup because of the space limitations, and because I got a good deal on a cheap 100Wx2 reciever (which says must be 8 or 16 ohm speakers). So now my question:
I have found a couple ideas of what I might want to build:
http://zaphaudio.com/BAMTM.html
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=302-930
Problem with the first one is that I cannot find anywhere on the page where it tells the total impedance of the speaker, and it cant drop below 8 or I am not sure what my cheap amplifier will do.
Problem with the second one is that it says it is a 4 ohm speaker, which might not work either. Any way to adjust the impedence by adding a resistor or something?
Or how can I calculate the impedence of the zaphaudio project?
By the way, here is a link to the reciever I bought:
http://www.circuitcity.com/ssm/Sherwood-Stereo-Receiver-RX-4105/sem/rpsm/oid/121266/rpem/ccd/productDetail.do#tabs
Thanks for all replies! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Also, this setup will be used with a subwoofer, not sure which yet, havent decided what to build/buy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Are you talking about a subwoofer kit or a MTM kit? I havent looked at their website yet. Gonna do a search later to see if any forums have any good reviews for them.
Thanks for the link, I checked out the site and the forums. Seems to be alot of smart peoples there. I posted a thread similar to this one.
Is that what you had in mind? Or was I supposed to keep searching thru the forums till i found the answer to my stupid question? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
waaiitt a minute i get it, i found that project, thanks for the help!
but wait, the impedance curve for the setup dips below 5 ohms for a good chunk of the midbass region...wont this cause a problem with my reciever (limited to 8 ohms or greater?)
One school of thought says. Build some quality speakers and upgrade the power
plant later if it's too weak to drive them. What do you want? cheap speakers
+ cheap receiver *or* quality speakers with the upgrade path to a better source
later? The Zaph and HTguide designs are good ones to follow.
hey thy, i want quality speakers, have no doubt about that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif My power plant is good for 100 watts @ 8 ohms which should be plenty to drive a nice pair of mains. Since they will be mains I figured something with a couple of decent midrange woofers would suffice due to the extra cone area and bigger sound.
Ultimately, I want to spend LESS than 500 (400 is better for me) on a nice pair of mains. Wanna build them myself. But those designs all seem to produce an nominal 4 ohm impedance. I would rather not design something myself as that might lead to failure. Whats your advice? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
[FONT=&amp]Just my $.02 on this. Go with anything but the ASSendent set.[/FONT]
[FONT=&amp] [/FONT]
[FONT=&amp]I would categorize the arbiter set at mediocre at best… It’s not bad but you can do much better….[/FONT]
thanks for the input B&W, although its discouraging cuz its the only kit I have found that is an 8 ohm nominal load (my reciever needs an 8+ ohm load).
I do appreciate the honestly tho, I need to hear from people who have actually heard the speakers. Thanks for the advice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif .
If you think about it, there is only two paths to getting quality speakers.
You engineer them yourself or use a proven design from a reputable source.
Engineering the speakers yourself, DIY style is fun, takes time and money.
If you don't have the time and extra money to spend money on DIY experimentation to get
the best design for you, then you have to gamble on a proven design from
the folks mentioned. It's also gambling because reputable designs won't
guarantee that you will be satsified either, look at some high end home audio
speaker manufacturers who have proven winners, those designs won't satisfy
everyone. Essentially you have to pick the lesser of the evils -- to spend the time
and extra money by engineering your own - or do you gamble on a reputable
design and accept it's sonic personality?
I place speakers at the top of the SQ list. So, I would find some designs that
have testimonials behind them from other builders and worry about the 4 ohm -
8 ohm impedance issue last. If your receiver is cutting out and can't drive the
quality speakers then you need to upgrade it. You can buy used sources for
much less than brand new. Look at reputable receiver brands known to drive
speakers better even if impedance dips low, ie Denon, Onyko, etc., *or* if
your receiver has RCA preamp out, get a seperate power amp to drive the speakers.
LilBassGuy
LilBassGuy
Hiding
pwnt by pat
