want to build a new box, have a few ?'s
  • 4
truckstoy
truckstoy
i want to build a ported box for my 13w7, right now it is in the jl prowedge sealed box and would like to get a little more out of it.
want to use areo ports and try and keep the box around the size i have now.
was thinking 22L x 18H x 18D = 5581.12/1728 =3.22 ft3 less .21 ft3 for the sub
now that is 3.04 ft3 internal volume.
on the 1 site i used for a calc. using 2 4" ports on a 3 ft3 box tuned to 34htz it says port lenth of 16.6" so i will assume that is 16.6" ea. (not sure)
? 1. do not know how to figure out port displacement.
? 2. will this be a good box for my sub
any help would be great
mike
Let's see here
The 16" is for each port
Port displacement is just a matter of finding the volume of your port, then subtracting it from the volume of the enclosure. So pi*r^2*h for volume of a cylinder
Sorry can't help ya with the enclosure size, haven't dealt with too many w7's ported //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
are those outer dimension?
if so, you'll need to make the box quite a bit bigger to make up for mdf and port displacement.
those are outer dim. so i did 20.5 x 16.5 x 16.5 = 3.22 ft3
jl reccomends 2.375 for ported
i wanted to keep the box as small as i could
would a better sealed box help in my wanting more instead of the jl box
mike
those are outer dim. so i did 20.5 x 16.5 x 16.5 = 3.22 ft3jl reccomends 2.375 for ported
mike
Depends, a little larger enclosure could increase efficiency but you don't want to go too far and over power it. Ported would definately make it louder. I just don't know a good size to recommend //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
this is what i have now, would like to keep it pretty much the same only a ported box, i want sub up and port to the back but on the bottom not side so i can put a window in.
Looks like you got plenty of room there my brother . Might have to mount the amps in front of the enclosure though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok, with those dimensions (22 x 18 x 18) with two 4" dia 17" long ports I get:
~3 ft^3 net, tuned to ~33Hz
Seems like a pretty good plan to me. I don't have experience with the driver, but it meets the manufacturer's specs quite well.
EDIT: forgot driver displacement, it actually comes to about 2.8 @ 34.5 Hz Just add an inch to the overall height (or width) and you're back to 3 @ 33Hz.
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
truckstoy
truckstoy
truckstoy
Scotch Plains, NJ
xluben
    May 31, 2024
    May 24, 2024
