wanna see guts of apsm-1500
Got my three amps today can't wait to see what they do
Have you done any testing???
what else do people want? lol I'm sorry that it doesn't make you a sandwich and wipe your *** while powering your subs for 120 dollars.
I dont want anything wiping my *** and making me a sandwich at the same time //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Just got them all in just got to clean up the wiring then I'll see how the sound
http://i289.photobucket.com/albums/ll225/L77543020/6fae5406.jpg
Just hooked everything up and it sounds great turn on fan is a ill annoying but it only last a few seconds,but for 340 total can't beat it don't know how long the amps will last but right now it's great,the only problem I have are the terminals screws,there not the same as the ap 1500 and the screws can easily be stripped if you screw and unscrew a lot,went on a long drive played them at full tilt and they barely got warm
I'm thinking of getting two of these and running them strapped. My question is how do I set them with dmm? 1500 x two amps = 3000 then x 2ohm's = 6000 then √ that to 77.45xxxx. Is that right?? Thanks
I think the way that the ap's strap is through rca's instead of a phone cord...I think you have to set the gain individually for each amp (1500w @ 2ohms per amp)
i have 1 apsm 1500 hooked up to a single ap txx-be15 tuned to 32hz [only gets the amp to 1.8 ohms before rise //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif ] and its the best sounding 250 bucks I've ever spent.
Lmfao. Another 13 pages about this amp.
Of course if were in here earlier, it would have gone 30 from people getting butt hurt about thier $120 flea market garbage.
Do you guys rememeber when people got made fun of for buying gear off of eBay?
Well now you can get anything on eBay even sundown
Well the 120 flea market amp has been proven to do rated or very close. What's wrong with that? Just don't like the audiopipe name? Sure its probably not the most durable amp out there, but it makes subwoofers go "boom" just the same as high dollar amps...
this thread came up at the right time... I'm considering an upgrade to the 1000watt version of these. I'll only be pulling a 700Watt load from it but **** it's so cheap. Just not sure if I should get the 1800W since it's only like $100 more for future proofing since I seem to keep upgrading... its just never enough.
Also other "flea market garbage" don't have demo vehicles or are even suggested when someone wants to do a budget build,never seen a boss amp get 13 pages worth of coverage
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
SPLaudio
SPLaudio
upstate ny
d77543020
    May 12, 2024
Brendon Jenness
    May 11, 2024
