Wall is done! Pics!
eww... audioyawn... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
bet nobody seen that coming... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I LIKE IT!!!!! Nice jeep, Im digging this! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Really nice... for reals. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for the input guys! I'm seriously thinking about making the 3" ports 4" but i want to know for sure that it will be worth the time i'll spend cutting out new holes, and re-spraying carpet.. What do you all think??
It may not make a noticeable difference to the ear (other than port noise), but it will in comps and performance with the sub. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Looks nice , but choked . Is the enclosure shared ? Why can't you just make a big arse slot port right in the middle between the subs ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
x2 with the big ass slot port
If those are three inch ports , you could easily fit a 10" x 14-15" port in there . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Two 8" Flared ports.
I've got the hook up.
Flared ports? Never heard of um..
I could do a slot port but I would have to rebuild the actual wall because there is two peices split down the middle.. Had to make 2 to fit it in.. I think my only option would be to just make them 4" ports..
Enslosure is shared
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
917
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
Mr Bojangles
Bullhockey
Mr Bojangles
H'burg MS
Pop da Hatch
