Walk-through < 8 15's
so, you couldnt do a 16 volt system with just one alt. charging at 16 volts (i know it will be technically charging at more then this)?
No you cannot, Unless you can configure a way the vehicles brain sees a 14v charge then yes. You have to realize the pigtail connectors in your factory alt control the entire ECM of your vehicle. If that sees 16v, say buh-bye.
I was very impressed with your last install, (if I could get that kind of output in my car id be happy) but this looks insane, congrats on getting back on your feet and getting this rolling. Staying tuned //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ya, thanks bro! Losing the last job was tough. Moved back in with parents till I get a little more money in the bank.
Last setup was pretty intense for me. if this makes me sick from sitting in it, I will be content for a while.
got some specs on the enclosure: size, tuning, etc...?
Might cause an avalanche in the Rockies with that thing when it's done...
Enclosure is roughly 55 cubes, set tuning i believe is around 28hz. I did not design it so I dont know the in depth specifics.
steel frame for the box or just layers of mdf?
still pondering the idea of 1/4" square tubing.. With multiple layers of oak and hdf, I dont feel a steel frame is uber necassary. Maybe if I decide to do 12 15's in the future.
weight and cost. yeah welding might take a little longer but then you dont have to use as many layers
true, at the moment, I dont have enough access to a welder to want to make an attempt at it. Not to mention my welding skills need a little brushing up.
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
Stream? Unlikely https://www.smsl-audio.com/portal/product/detail/id/809.html https://helmaudio.com/products/boltdac You might can stream in...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
TnT_Sounds
profiling gets **** done!
TnT_Sounds
Colorado
AcidikBass20
    May 16, 2024
    May 16, 2024
