Volume is low but audio is very loud
thanks, I'll play around with it later. is it bad for the EQ to be at powerful aside from the fact that it ruins the balance of audio such as in my case?
theres bands of EQ, go to your custom and on the further most left side those all control the bass frequencies, its no different then using bass boost. as long as that side is tamed, you can do whatever the hell you want on the middle and right side. Always custom EQ, never use the presets.
thanks, got a suggestion on a good EQ for bass heavy songs? like hiphop/stuff like that
again FLAT on any bass frequencies period or else you'll blow everything up literally. On non bass frequencies, just play around, doesnt take a rocket scientist to play around.
376
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
i did end up getting the amp and subs you suggested, looking forward to hearing what it sounds like as soon as the stuff gets here and the weather...
43
They are. But, after using sort of them, i think best way is to root phone and do some real system modifications with Viper.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
76
gud
CarAudio.com Recruit
gud
Florida
Jeffdachef
    May 12, 2024
Brendon Jenness
    May 11, 2024
