voltage
it depends on what amplifier. if you're wanting to run voltage levels above the standard 14.4 thats some somewhat in-depth stuff. if you're just looking to get rid of voltage drops (im guessing this is what you're talking about) start with "the big 3"
Not with your main vehicle power supply as you'll run the risk of frying your vehicle's electronics.
And not all amplifiers will handle an input voltage above 14.4V.
Unless you are competing, it's not very wise to spend the time and //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif to support a higher voltage system.
What is your reason for wanting to run a higher voltage? Just more power?
how much is the maximum voltage i can put through the amplifier is it better to use a d cell battery dual altenator kit or capacitor to get higher voltage
I would def. power your amp with a capacitor. Wire three 10 farad caps in series and you'll be bangin 'son //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
take it easy there, thats ALOT of powah!! //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
don't really know much about capacitors but will look into it just wanted more wattage right now its hittin about 710 watts ( 14.2 volts x 2(25)amp fuses)=710 would like to get it to at least 800
ejfromwestbay
ejfromwestbay
sacramento. ca
terra
Mike Mccabe
