Voltage!!!
big_mofo
Im Da *** Man!!!
alright, i have a 2002 Buick Regal. Stock alt is 120amps. i have the big 3 done with some extra 4ga wire i had.. now my question, when my system is on full tilt (35/60) the voltage on my 6800mp shows between 11.5-12.2, why is the drop so bad. when i had my crossfire bmf600d it dropped to 12-12.5, an it gets lower now with the kx1200.1. as soon as i get the money i am goin to do the big3 in 4/0 an i know it should help a little, but is there something wrong with my alt, or something?? i am a little stumped. any help would be appreciated guys..
yes, i would like 4/0 but i may do 2/0, idk
For almost all users upgrading the Big 3 to 1/0 is sufficient. Unless you plan on pulling some serious current I cannot see the expenditure of going with 4/0 cable being justified but to each their own, I suppose...
My Big 3 is done in 1/0awg and running a Kenwood Performance Standard KAC-PS500F four channel and a Diamond Audio D61500.1 monoblock (@ 2 Ohms) I get absolutely zero dimming even with the tunes cranked pretty hardcore.
do you have a new alt?? i was just plannin to go ahead an do 2-4/0 bc within the next year i will be upgrading an doin a wall of 4 Massive CW15's off of either 4 KX1200.1's or 2 2500D's, which is when i would get my 260 irragii alt an 3 Group31 yellow tops
Not new, exactly...
I had my OEM alternator rebuilt/upgraded in its factory case.
It was stock-rated @ 75a @ 14.2vdc and now does 85A @ 13.8vdc at idle and 165a @ 14.6vdc at anything over 1500 RPM. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
reason why it drops is because you have a bigger amp pushin the subs... it will **** more juice...
maybe see if you can find something more powerful than yellow tops...
that amp draws around 150 amps...right?
i think it does...
anyways you just need to upgrade the alt... you can get by with a new battery..
but you will still need a bigger alt...
big_mofo
Im Da *** Man!!!
big_mofo
Hammond,Louisiana
Duke
