yes also... lol its not the safest option, i got a volt meter in my blazer and i always pay attention to it. most of the time im not running min over 1/4 of volume, well now i dont run it over 1/4 period unless i compete because i have a stronger amp then before. if you dont run a fuse i urge you to get a volt meter if you dont already have one. its not safe but you would be surprised to how many ppl dont run fuses. if you know what you wire can handle and dont try to push to much through it, i think you will be fine. like mine is mostly 2 gauge wire, HOWEVER its pure copper and its about as thick as a 1/0gauge. and the runs are only about 1.5 - 2ft at most so they will carry 250amps no problem. my big 3 is also in 2 gauge and the longest run is 1.5ft. so pretty much as long as you know what your wire is capable of you should be fine with no fuses just make sure all grounds are good.
