Voltage experts!! Help!!!
Ya but the thing is I feel I shouldnt be dropping that low. With 1 g34 2 g31s and a 250 amp alt. I am idling at 14.4. Hell it stays 14.4 until I REALLY crank the bass up. Then it just all goes to hell.
Its a pretty big amp....its the same as a RD 3250.1 which is rated at 3750 watts at .875 ohm
Thats alot to put out gettin full power.......what do the dekas rest at?
idk thats odd i mean i am only running a zx1500.1 at 2ohms and a zx850.4 for comps and only have stock 130amp alt, no big 3 just a gold duralast upfront, a stinger spv70 in the back with a run of 1/0 pos and neg, so roughly 2200-2400rms on songs like blue berry yum or put on the front battery is around 13 back battery is around 12.5-12.7 and the amp is around 11.9-12.4
idk why i am seeing such a voltage drop from the batt to amp its around a half volt and the back battery to front battery i am losing about a half volt as well
Ya what Ill do is just put a song on with a constant bass line. DMM the front battery til it stops dropping. Front battery will stop dropped at 12.4-12.5 is where it sits at full tilt. Then Ill go to the amp and it will be at 11.7-11.8
Use one positive and one negative run. You probably have a crappy ground or just your frame isnt very conductive. Eleminate the grounds completely and go too the battery up front and the voltages should match up.
mazzasec
Banned
mazzasec
ATL
MisterGrubbs
