voltage drop
Hook your DMM's contacts directly to the terminals on the amp where the wire is connected. But I can already tell you this, the voltage drop will be even more there (lower voltage) than at the amp. 10 volts is already major voltage drop, a potentially harmful amount for your equipment (especially the amplifier). I suggest fixing whatever flaw you have in your system thats creating this much drop.
sounds like you have been slowly killing your alternator and in return the battery has sufferd also
i suggest getting on ebay and buying a high amp alternator there ( ive had great success with HI AMPS POWERMAX and DBELECTRICAL)
and then replace battery also if needed or give it a good proper charge and see what it rests at
edit.. do the big 3 also
0g is best
I have a regular battery under the hood and a stock 103 amp alternator. I had the battery n alternator tested, they both passed. I have extra 4 gauge, will that b sufficient enuf or should i buy hot gauge for the big 3? Will my system pound harder with the big3? I bought the cheapest head unit hey had at best buy, that wouldnt have anything to do with it, would it?
Upgrade just arrived...SHCA Black friday sale for the win. Even more voltage drop, here I come.
18
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
I was thinking 2 aught wire an do you think it would help if i took the secondary battery ground ran it through the ground sensor an tied the...
blimpthepimp
blimpthepimp
spring hill
blimpthepimp
maylar
    Jun 2, 2024
    Jun 1, 2024
