Voltage Drop
i have a small one to no good batt avl for mine im going to get some back batts anyday now and for you just get the hc2400 for the back run 1/0 to it and you will do fine but your volts are droping that low fast trust me the batt is going bad get it checked
will do.. its pretty new.. it is about 1 yr old..
mine was only a year old but get it checked then pm me how it turned out when they check it out be sure to have check to see if it has a cell going bad with the load teaster
and mine probley went bad becouse i played it to long turned up but get a good back batt when you can or i can say if the batt is bad your going to make the new one go bad so get a second batt quick just keep it down till you get one or only play it with car running and not to long
ya but what if they don't do the load test at the place i got it? it holds volts perfectly otherwise.. and last time it died on me i had this system as well.. last time it just straight up died.. held a charge of about 10.5 car off.. 13.3 car running
when mine was bad it sat at 12.6 volts and with car running 14.1 and still had a bad cell volts would only drop fast with the added load take the load away the batt volts would go back up
KyleBechtold
Quit reading this
KyleBechtold
Tampa, Florida
KyleBechtold
