voltage drop
orioles26
At hte batteyr i have 14.4 volts but when a check the volts at the amp, at most it will be 13.5 volts. Is this normal, or is there something i can do to fix this. I have 2 gauge wire from the battery that splits into two four gauge wires with a distro block. My sub amp is a hifonics 1800d and my component amp is a profile 150x2.
First - He has 14.4 at the battery, so thats fine. Second, depending on the amount of draw he has. 2 gauge could be more then good. Upgrading the ground might help. Fuses inline will cause a slight loss in voltage (check voltage after your inline fuse under the hood). When you check the voltage in the rear do so with the stereo off to make sure the draw of the system does not effect this reading. When current travels through a cable the resistance in the cable causes a loss over the run of the cable. Smaller cable and higher amperage makes for higher loss.
LOL - was the block made out of steel or something? Sounds more like you had a bad connection inside that block rather then the block itself. Most blocks are 3" in size, to lose 2V over a 3" span points to bad connection
Running double the same size wire would offer less resistance, but is not going to be any better then the right size wire used along with distribution blocks. And as stated if he has a fuse block, the fuse will cause a slight drop in voltage.
orioles26
orioles26
Severna park, Maryland
knukonceptz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
