VM audio encore 12 "high-excursion" subwoofer
DirtyDuzit
AZ
Got two of these a month ago (set was 185 at the time) can't find anyone with these subs.
2) VM Audio Encore 12-Inch High Excursion Subwoofers | ECW120 (Pair) : VM-ECW120 : VMInnovations.com
claim 1500rms, I had 2 on an alpine mrx100 ~1000rms anyways the amp went out and I upgraded to a ppi black ice 1800. Just running them on an old rockford amp till the ppi comes in.
Curious to see if these subs will be able to handle the 800~ rms each.
Anyone ever seen anything about these?
i have same pair of subs, had a planet audio ac4000.d.1 mono block amp, wired at 1 ohm, amp was rated at 2200 rms at 1 ohm, sounded awesome til the amp gave out and now i went with a boss nxd5500 class d mono block hoping to have more bass, also the box i had the subs in was 29 x 20 x 20 inches and ported to 42.5 hz
38
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
377
DirtyDuzit
AZ
bass junkie
    May 24, 2024
