Very Quick Question About Tuning Boxes
Man, if someone could do this for me really quick im going to start on my box as soon as you post it up. I really need this done, please help me out guys
first off, the height of the port should be 15.5" (I had the cell referenced, you must have deleted it).
and unless you add a corner to the port it won't be that long.
without adding a bend to the port (one straight wall, stopping 4" short of the back wall), i get:
4.14 ft^3 @ 36.33 Hz
you need to learn how to use WinISD //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thank you so much dude, i know well ive only had a few days to mess with WinISD and im leavin this friday so after work everyday im workin on this box and trying to get all the little things fixed on my truck, i just put an escalade front end on it and between trying to make brackets for that and this and work I dont have any other time. you have been so much help to me thanks so much
10
973
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
JakeM
JakeM
Houston
xluben
    May 20, 2024
    May 20, 2024
