scarolinablazin
You Can't Fix STUPID
you saying 1 amp of fusing for every 10 watts?? is that where you get those numbers?? just curious as i`ve run 600+ watts on an underhood 30 amp fuse with no problems.If you are running one I would fuse it at 200 amps on each power wire. Definitely put a battery in the back and use that for your d-block.
and also, it would be much better to have just 1 fuse if possible. get a blade fuse holder like you would use under the hood then a D-Block connected on the shortest piece of wire you can.
