BiaBia
US Amps Xterminator xt800.2
Type: Class AB Monoblock Power Amplifier
Ultra High Current MOSFET Devices
MMT Regulated Power Supply
35 Nanosecond Switching Diodes
High Capacity Power Transformer
Multiple Bypass Capacitors on Incoming 12V Supply
Time Delay Turn On with Opto-Coupled Muting
Pulse Width Modulated Power Supply
Thermal, Short Circuit and Reverse Polarity Protection
High Efficiency Class AB Design
Active Constant Current Bias Tracking
Dynamic Power: 800w
RMS Power (2 Ohms): 2 x 200W
RMS Power (4 Ohms): 2 x 100W
RMS Power (4 Ohms Bridged): 1 x 400W
THD:
Channel Seperation: 58dB
Damping Factor: 250
Input Power Supply: 12-18 Volts DC
Signal to Noise Ratio: >100db
Frequency Response: 10hz to 50Khz -1.0dB
Low Level Input Sensitivity: 20mv to 6v
Selectable Crossover: HPF / FULL / LPF
Continuously Variable Low-Pass Crossover 40-250Hz @ 24dB / Octave
Continuously Variable High-Pass Crossover 40Hz-1KHz @ 12dB / Octave
Subsonic Filter: 15-40Hz @ 24dB / Octave
Bass EQ Control: 45hz - 0 to 12db
Line Outputs
Platinum-Plated RCA and Power Connectors
8AWG Power Connectors
Indicators: Power, Protect
Weight: 4KG
Fuses: 1 x 25 Amps
Dimensions (mm): 63.5(H) x 222(W) x 248(L)
$75 shipped
Great condition. Two small nicks, one on amp face and other on bottom edge; about the size of the top of a pencil. I've had the amplifier for 5+ years, it's been in storage since Feb 2009. Verified excellent working condition and great cosmetic condition last week. Barely any usage!
Dynamic Power: 800w
THD:
Damping Factor: 250
Line Outputs
Weight: 4KG
Fuses: 1 x 25 Amps
$75 shipped
![IMG_1526_zps185bed66.jpg](/proxy.php?image=http%3A%2F%2Fi174.photobucket.com%2Falbums%2Fw85%2Fulyessz%2FIMG_1526_zps185bed66.jpg&hash=20f14e625f1c32329399d9f1ef305822)
![IMG_1528_zpsd3155861.jpg](/proxy.php?image=http%3A%2F%2Fi174.photobucket.com%2Falbums%2Fw85%2Fulyessz%2FIMG_1528_zpsd3155861.jpg&hash=86cd0aa6fb047378913a11b1de2c3088)
![IMG_1530_zps3da9af81.jpg](/proxy.php?image=http%3A%2F%2Fi174.photobucket.com%2Falbums%2Fw85%2Fulyessz%2FIMG_1530_zps3da9af81.jpg&hash=315e3b97c20df9b1d4e8aac4cb8a0eef)
![IMG_1531_zps9c2a0e63.jpg](/proxy.php?image=http%3A%2F%2Fi174.photobucket.com%2Falbums%2Fw85%2Fulyessz%2FIMG_1531_zps9c2a0e63.jpg&hash=d7d41818fc67a38ca1899da4f6a1c2c6)
![IMG_1527_zps8d2f4724.jpg](/proxy.php?image=http%3A%2F%2Fi174.photobucket.com%2Falbums%2Fw85%2Fulyessz%2FIMG_1527_zps8d2f4724.jpg&hash=d58b4ae8b64cb670c894c28c2fe16be6)
![IMG_1529_zps7431a369.jpg](/proxy.php?image=http%3A%2F%2Fi174.photobucket.com%2Falbums%2Fw85%2Fulyessz%2FIMG_1529_zps7431a369.jpg&hash=9ce72e979bad5439d5e26606edd2aad5)
