Question about grounding
jesse_00
Hey guys, I recently bought an aftermarket stereo and am kind of confused as to what to do with the grounding wire. I know I am supposed to attach it to the chassis somehow, but I can not seem to find a spot where I can do that (1998 Passat.) Attached is a picture of my current wiring situation (right leads to HU, left leads to wire harness)
I am wondering if I can just clip and strip the right wire and solder it to the one on the left instead of attaching it to some place on the chassis. What are your suggestions?
chassis ground is what it is intended to be connected to. look for metal inside the dash - look for factory ground wire locations. if you cannot find one, then yes, you can ground to the wire harness ground (try to trace that wire in the harness).
jesse_00
jesse_00
United States
jesse_00
