Upgrading from Alpine type S 12"-
  • 4
Mrcash05
I currently have a newer model 500rms Alpine type S 12" in a small sealed box. Sounds decent and pretty loud but looking to upgrade to higher quality sub around 450-500rms. Would like to try ported box and was thinking of getting a 10W3v3. I listen to rap and rock and would be in the back of a small hatchback so space is limited. Would the 10w3v3 sound louder/better than the sealed type s 12"? Any other recommendation you have in place of the JL? I have never had a ported box either just single 10",12",15" in sealed boxes ranging from 300-500rms. Not expecting to be heard 3 block away with any setup either.
Thanks!
The Type S is a pretty good sub...it will handle 500rms all day long...have you considered trying it ported? In 1.75cubes tuned to 32hz with a ss filter applied at 30hz@12db you can feed it 800rms before it reaches x-max. What amp do you plan on using? When going ported, a good subsonic filter is crucial.
Is the type s even worthy building a new box for? Would I even be able to tell a difference in up grading to a higher quality sub? Will be using amp only in 4ohm mode keeping system low power in general.
For sub
Diamond audio D31100.1
450x1@4ohms
800x1@2ohms
100x1@1ohm
Kewnood ddx672bh
JL TR650‑CXi front and back
Diamond audio TX300.4
Stinger and sky high wiring.
Optima red top under hood with stock alt for now
For sub
450x1@4ohms
800x1@2ohms
100x1@1ohm
Kewnood ddx672bh
lets take it back a notch and tell us your max dimensions you are willing to give up in L x W x H. A picture of the hatch/trunk would help as well. But dimensions are needed.
Using the dimensions you provided minus the thickness of 3/4inch MDF you're looking at 17.5x19.5x13.5=4606.875 (cubic inches)/1728 (1 cubic foot in cubic inches)=2.66 cubic feet internal space NOT including any port/brace/speaker displacement....I think you could get a good ported box for a 12 within those limitations.
Also your question about the Type S being worth trying a nice box...it depends on the model of Tye S you're using...the older models weren't all that impressive...however the newest version is actually pretty nice. It's an underhung coil/motor design with 15mm of throw with a reasonable mounting depth and moderate power requirements...you could do a lot worse in a subwoofer.
With 1000@1ohm (or even 800@2ohms) the Type R is a good choice...segmented magnet structure that allows for better cooling, a shorting ring, 'compound-radius curve' shape on the pole piece to help 'shape' the magnetic lines of flux, 20mm of throw, specifically designed grill...and handles gobs of power.
Good news is your amp has a variable subsonic filter(15hz-40zh) which will allow you to control the unloading of your sub below the tuning frequency of a ported box.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
172
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
565
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
915
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
When I stripped my factory system and started from scratch. I didn't need any adapters. I wired the new head unit wiring harness to the vehicle...
887
Mrcash05
Mrcash05
Grand Rapids, MI
Mrcash05
    May 16, 2024
    May 16, 2024
