*UPDATE* Amp shut off in middle of a song
  • 6
WaCk071
KS
So after finding time to inspect my amp further, I check the power line coming from my battery, and the fuse completely melted off the side that is going to the amp, I don't know why this happened. I'm planning on buying a new fuse soon, but I don't want it to melt again, so does anyone know why or how that would happen? Thanks for the help again!
Sent from my Pixel using Tapatalk
what size wire and fuse? have u been using this amp for a while no problems? check ground at amp make sure no wires pinched/cut anywhere..
It's 4 gauge with 60 amp fuse and I've had the amp for a month and have had no problems until now
well looks like u need new fuse holder anyway so get 80-100amp like this (i have new one sitting here waiting on terminals to install all end of week) if u order it make sure u tell them 100 amp fuse on paypal (i forgot had to order some they sent 60a) https://www.ebay.com/itm/In-Line-Car-Audio-APX-MAXI-Blade-Fuse-Holder-4ga-12V-24V-32V-DC-10-100A-Fuse/251628654761?hash=item3a963c90a9:g:LW8AAOSwGUBZ7MZX
I got the other end of the fuse out it was just stuck in the fuse holder, so I bought some new fuses for now but I'll have to order some bigger fuses
https://www.ebay.com/itm/XSCORPION-GOLD-WATERPROOF-MINI-ANL-Fuse-Holder-0-2-4-Gauge-Car-Amplifier-Install-/273013215953
This is the type of fuse holder you need under the hood, an ANL fuse, and waterproof be best.These are made by Stinger which are pretty solid blocks that last and are pretty much some of the best blocks ive ever used and still use today.You are currently using a very Cheap AGU fuse holder of which is very low quality and generally used for amp inline fuse holders of up to 60-80 amps max,and are very unpredictable as to lasting or made of good quality.Never cheap out on your main Supply blocks or inline fuse blocks.You can choose your fuse size/amperage at check out. Id recommend getting at least two more fuses to place in your console to carry for future needs.ANL fuses are pretty much bullet proof and work fantastic
Sir, that is some Cheap junk.. Please dont recommend stuff like this for main supply needs for others
If your fuse holder is melting it is NOT a fault with your ground it is with the fuse holder (or just the fuse) or you did not have it good and tight. The heat is being created at the point of resistance not 15 feet away!
tried to find 4 ga one on gp but all i saw was 1ga.. may pm him see if he has 1 cause i just bought that cheap 1 cause mine in 13 yrs old, now i don't wanta install it.. i have 5 100a maxi blade fuses so wanted to use those and stingers i see say 20-80a..
Yea man my dad is off today so when my car is ready at the mechanics gonna go get it and take it over to his place and hus gonna help load them...
16
460
@audiobaun @Doxquzme Yall got me excited!!!!
14
966
I recently tried this stuff and it seems as good as the Duratex I've used prior. It's almost half the cost too...
I just clicked on six separate threads and they went well. Seems to have worked.👍
Hi Everyone, I just updated my 2012 Passat SEL from the Factory RDS to a Kenwood DMX7709s to enable CarPlay and install a backup Camera. I know...
WaCk071
WaCk071
KS
    May 24, 2024
