Up firing sub in Integra OK?
Big Dee
Would it be OK to mount a sub facing upwards in my trunk? The only thing I'm worried about is the hatch cover that would be a couple inches away from the driver. Would that make any difference at all?
It's a sealed enclosure.
Sorry should have been more specific. Yes it's the DC2 Integra.
Thanks for the reply, if it actually hurt performance at all I was thinking of cutting a huge hole in it and putting in some acoustically transparent material, but hopefully it won't be a problem.
i face my ported idMAX so that it fires toward the rear of my integra. i can't face mine up because of the wire comoing out the back of the box but i get best results with it facing toward the rear.. is there a particular reason u want it firing up? does it sound better to you or is it for aesthetics? just wondering
Just aesthetic reasons. I want the speaker on the longer side of the box as opposed to one of the ends. I am building it myself so I can put it on whatever side I choose.
Did you ever try it facing upwards? What did it sound like?
i never tried facing it upward actually my box wouldnt fit that way i dont think. and if it could i still wouldnt be able to because the wire runs from the sub to outside the box the box doesn't use terminals.. if i flip it so that it faces up im afraid of pinching the wire off.
Big Dee
Big Dee
Ohio
noob with an RS
michigan born
    May 14, 2026
michigan born
    May 14, 2026
