JimJ
Tangled Up in Blue
Two questions, mostly adhesive-related...
I want to mount my Xovers on the inside of my doors, up against the outer door panel below the window. It'll be going up against three layers of sound deadening, and since I can't drill there I need sonething to hold it in place. I don't think Liquid Nails will have enough holding power; what should I use that would hold and be able to withstand the temperature extremes? I was thinking CA or epoxy of some kind...correct?
I have a similar question with deflex pad or whatever foam I end up using for behind the drivers. If you installed it, what did you use to affix it to the deadening below?
Thanks.
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Thanks.
